Roccat Kave 5.1 Surround Sound Headset Arriving Monday
17 Oct 2002
Stoke
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels.
- Real 5.1 Surround sound with speakers aligned at a 12° angle
- Microphone with mute LED fully rotatable and completely removable
- Tip’N’Control desktop remote for central management of all volume functions
- Dual sound-profile with movie and game settings
- Solid aluminium hinges enabling heavy duty use
- Hand-sewn comfortable earcups featuring external noise cancelling
- Adjustable vibration unit for a realistic gaming experience
- Headband with three pads for equal weight distribution
- Easy to carry folding and compact design
Just £74.99 Inc. VAT
BUY NOW
its an interesting feature tbh. i wouldnt knock it till i tried it. that reminds me, i really reaaaaally want some rump shakers for my sofa
But surely all you need is to pressurise the room with a damn good sub :D:D
So butt shakers (cool), ear muff shakers (lul wut), and what next........ ball shakers ;)
i cant get away with it these days what with living in a flat. but that doesnt stop me using 15" sub every now and again :D
ball shakers? erm...hmm
meh, these 4.1 / 5.1 / 7.1 headphones have all been slated in the past because they use an array of tiny cones and drivers instead of just 2 big cans that can utilise Analogue Stereo Pro-Logic to expand the field of play.
Best thing to remember, is that unless you're the terminator, you have 2 analogue ears, most people that trial these mini-speaker-array headphone setups just complain about the verry tinny, over specific sounds they produce :(
Guys I bought a pair of these headphones and previously used Razer Barracuds'a! These blow away the competition. I love them! There so comfertable and I game everyday for about 5 hours. Worth every penny, and would have paid more. Sound quality better than sehnihizer! glad i noticed them on ocuk :) im happy for about 50 years now jsut need a good mouse and after these i might try the roccat kone :)
The sound quality better than which set of sennheiser?
They won't last 50 years.
Yes, get a mouse, made by the same manufacturer as your headphones... jack of all trades springs to mind.
I used Sennheiser HD 280 Pro before which were great but not a touch on these babies
lol was jokin about 50 years just expressing my happiness :)
Have you tried anything roccat before? I think there products will test the big players atm such as razer, steelseries etc Hard to judge if you havent tried!
