Hi,
I have been having BSOD nv4_disp.dll errors for a while now while gaming only, sometimes it only takes 10-15mins and sometimes i get a good hours gaming in (normally happens half way through a CSS match).
I have browsed a few forums, done a lot of searching on the net, downloaded and installed more drivers than i care to list and have come to the conclusion its the power supply.
I read that my card requires 36amps from the 12V rail, so i looked up what my psu gives (enermax liberty 500w) and found i get 32amps out of it. So im guessing that when i get to a certain point in a game that for some reson requires more out of my hardware my power supply cant give my pc what it needs
So basically i would like your opinion on a PSU that should be capable of running the card at max load.
I have a Leadtek GTX260 Extreme+
I was looking at the Corsair TX 650W ATX SLi Compliant Power Supply as its on offer this week.
Do you think this will be ok or would i be best using something else, im not wanting to spend much more money and not over £100.
Thanks for reading!
Thanks for reading!
