Good morning all.
I am looking at building a Dual Xeon, Quad Core machine, using the new Nehelam processors and i am trying to work out some stuff about this...
So, the CPU block for an i7 should work with the Xeon (since they are both Socket 1366) and in theory all i need to do is add a second CPU block to the loop, but i also want to cool a GPU (Probably a GTX 280 or 285, maybe even 2).
So, which way should this work? initially, i have 3 theories:
RAD -> Pump -> CPU 1 -> CPU2 -> GPU -> back to start... but wont the water from the CPU's be a LOT warmer? you may end up heating your GPU!
RAD -> PUMP -> Splitter -> CPU 1 -> CPU2
-> GPU -> (maybe memory) but this then begs the question: How do you properly split the pipes?
-> CPU2
-> GPU -> (maybe memory) same as above, but split 3 times...
any help on this would be great.
Thanks.
-> CPU2
Thanks.
