How much quicker in games are I7s vs older Qs ?
20 Aug 2006
I'm tempted to upgrade but I think probably on reflection the cost is greater than the benefit ?
was restricted up till now with Vista OEM - so couldn't change mobo - but now W7 RC - and full version ordered thats not a problem.
currently have a Q6600 @ 3.5 gig -with 6 gigs of RAM @ 790 CAS4
(or sometimes running at 3.3 with RAM at 1100 CAS5)
lure of a >4.0gig I7 is tempting - but I'm just not really sure if there will be an oticeable difference ?
(graphics cards is a 4890) - I like playing Arma 2 and FSX
cheers, Mark.
not quicker at all really....q6600 at 3.5ghz and a 4890 should really be all you need for some time to come.
ah ok thanks - that should be a :( for fun-ness but :) for the pocket
my Q6600 gets VERY hot - I mean its at 1.5375Vcore in bios - but its stable - and only gets hot under small prime - not with real games.
this P5B Deluxe has lasted me the longest out of any mobo ever I think - I'm way over 2 years now - not sure how long exactly - must be a good 2 1/2 years though
Tbh your current rig will handle games fine, a q6600 at 3.5ghz is still a pretty powerful cpu.
I7 only shows it's legs once you get into xfire 4870x2 or sli gtx285/295 or tri/quad sli.xfire and then only at very high res (tbh you would need high res to justify all those graphics cards.
Ive found with my previous q6600 @3.8ghz and my current q9550 @3.8ghz as well, coupled with a gtx 280xt, any game i currently play runs perfectly well at 1920x1200. Ive thought about i7 as well but the high cost for the cpu and mobo has put me off a bit.
so looks like no difference whatsoever...
If you're only gaming then there's no need to get a top end CPU at the moment, it's debateable whether quad core is even necessary, although it will probably scale more over the next year or two when CPU physics is more heavily used.
I7 isn't a gaming platform, if you want a games machine buy a PS3 :)
might be better off waiting for the dual "I5" to come out if they clock as high as th rumours suggest and couple that with a GPU to suit the resolution you play at...
I thought i7 is worse for gaming.
There was a post on here when the i7 was quite new, which linked to a report on i7 V Phenom2 V a Core2 Quad. They only tested about 6 games or so, the Phenom2 came top in 1 game, in almost everything else the i7 can first, and the Core2 Quad came second.
Yet it was hailed as i7 sucks Phenom2 rocks.
Most games are GPU bottlenecked, but not all, the i7 has a better clock for clock performance than Phenom2 and Core2 Quads, so if its not GPU bottlenecked, the i7 should be faster.
i7's are very nice in World of Warcraft, which has fairly simple graphics, and an older cpu heavy 3d engine. The I7's based on the cheaper 1156 socket might be even better though, as they have a bigger speed boost in turbo mode, and its unlikely that many games will need the real I7's tripple channel memory controller.
I never understood why people are always hailing the phenom 2. The chips are cheap but good mobos are quite expensive...and people say they are awesome, amazing overclockers yet I don't think I've seen more than 3.9ish ghz for a stable 24/7 clock. Pretty poosauce if you ask me.
high-res performance does seem quite good though.
The i7 is not worse than the Phenom II in gaming, it's just that with the PII you can get basically equal gaming performance (on average, depends what games you play) for less money. That's why the i7 isn't touted as a gaming platform, unless you have a really high end GPU setup (where your CPU would be more important).
Worse value for gaming yes but it's the fastest and most efficient CPU on the market period.
Games are software applications like any other program, you don't get a CPU that destroys the competition on all fronts but suddenly chokes in games, games are simply the only application to have a massive hardware co-dependency which is a GPU.
Yeah I second that.
WoW is very CPU intensive whereas other games depends on the GPU.
