Delta 120mm work with Sunbeam Rheobus?
30 Jul 2003
Hi, im looking at this fan to go with my Thermalright IFX-14 but dont want it running at full speed all the time ..
I have a Sunbeam Rheobus which works with my vantec tornado just fine.
I was wondering if it would work with the Delta as well, or whether it would eat it and make it go pop
Many thanks
Just that the extreme is rated to 30W per channel and the standard is 20W per channel iirc. From what googled images show, the extreme has six channels compared to the four of the standard.
On the centre of the fan it should have a code, google that and it'll bring something up, but I think it's around 24W.
Edit:- Taken from a competitor's site:-
Specifications: 120x120x38mm, -->190.00<-- CFM @ 4000 RPM, 59.0 dBA, 24.00 watts, 2.00 amps, 12v DC, 3+4 pin Molex connectors.
You should be a real man, run it without a fan controller, and deck out your entire case in Delta's...
When I was a kid, I used to have a 2x60mm screamers on my alpha coolers with my celerons 433's, and a 120mm delta blowhole on the side ;)
bah :( ok ive ordered a zalman fan controller thing as people have that running hte fan currently :D
Didn't think of this earlier :( But you could do this:-
Purchase one of these
http://www.overclockers.co.uk/showproduct.php?prodid=CB-007-GE&groupid=701&catid=48&subcat=153
Then mod it to be 7v, then it could run off your fan controller. Even at 7v it still shifts a lot of air :)
Sorry to hijack this thread...
I bought one of the Delta 120mm fans as well as a Sunbeam Rheobus Extreme controller but the problem is, I have a Sunbeam Core Contact Freezer CPU Cooler and as this Delta is so thick, the metal long fan clips supplied with the cooler that keep the fan on the heatsink on the Core Contact Freezer Cooler won`t fit with the Delta on the heatsink because of the fans thickness, therefore, I don`t have anything to keep the fan on the heatsink. Does anyone have suggestions on how I would go about fixing this problem???
Thanks for responding.
Thanks everyone for responding.
I just used a bunch of those small plastic with metal inside cable ties you get with pc cables, and
tied them together just until I get proper long cable ties from OcUK.
