HDMI Cable
25 Mar 2007
NORN IRON
Hello
I have just ordered and a new TV (panny 42" G10) and am in need of a HDMI cable to connect it to my PS3
My question is, are the any things I should look for when buying an HDMI cable and why are there ones for like £2.99 and then ones that go up past £60 ?
Thanks in advance
It's a digital cable, so as long as there's transmission it should be fine. I bought a few £3 ones, and one was a bit dodgy because it was bent behind the TV, which I imagine wouldn't happen with an expensive or right-angled cable, but when it was working the picture quality was perfect, and the rest of the cheapy ones I have are still perfect. They were belkin I think, though not boxed, and I paid trade price for them, not sure how much they are in the shops, some places put insane markup on cables.
To say that any old cable will work is not strictly true. If a cable is badly shielded, the signal heading down the cable might be affected by outside interference so much that you would get breakup or complete loss of signal on the output.
Also, I'm not sure what the spec is for HDMI, but any signal (digital or analogue) is going to degrade over distance, so you might have problems with really long cables. If you wanted to get the HDMI signal over cable which is longer than the recommended distances, you would need some sort of line driver to get the signal further. However I'm not quite sure how many are available in the domestic market, but most people will have their PS3, Blu-ray player or whatever under their TV so this is hardly ever a problem.
All said though, it's true that most cheap cables seem to be up to spec and are not excessively long so you'll find most are fine.
I have had an odd problem though which I believe is more to do with my monitor more than anything. My PS3 connects to my monitor through HDMI, and with some HDMI cables you'll get a better picture over others. When I say better picture, I don't mean better colours or whatever. With the worse cables, the signal would be so bad you would get no picture, or very bad signal degradation such that you'd get lots of errors shown by green sparkles on the monitor.
Out of the three cables I tried, it was the cable with the second shortest length that gives the best performance. I suspect it's some sort of slight impedance difference between the cables or something that causes the difference, but it goes to show that not all cables are the same!
up to 10m seems to be the limit for cheaper cables.
however you can still spend less than £20 on a good 10m+ cable..
Highstreet in Exeter, £40 for the cheapest I could find going up to £120! Just bought one online, £3.75.
Sorry folks your ALL (well some of you)wrong I had this discussion with a mate of mine
He asked me what the differance was between a £90 HDMI lead and a £4 HDMI lead
86 quid i said.
In all fairness the more expensive ones look the mutts nuts hiden away behind the TV and that really classy shiney packaging looks sooo sexy in the bin afterwards.
So as people have said Cheap an cheerfull unless over 10-15 m then get a good quality cheap an cheerfull one
Better quality hdmi cables are able to be run over greater distances without the loss of picture than poorer quality cables due to them being less prone to signal attenuation.
I decided to buy a £50 cable myself because of the superior build quality not because I thought a £3 cable wouldn't do the job.
I used to use a £1.50 HDMI cable with a projector that cost more than 2000x that.
£50? Were you planning on mountaineering with it?
mate bought a cheap cable 2m fine with a 720p projector but as soon as he used it with his 1080p tv picture would drop out.
I bought a loaf of bread once that went mouldy after a day. I guess that means all loafs of bread will do the same ;)
ROFL !!!!!
Tony, you should have just bought a cheap cable. If it was DOA then buy another cheap cable from somewhere else. The more expensive cables still don't guarantee a perfect working cable, just look at the massive test audioholics undertook. Also have a watch of the x4 HDMI videos on avforums tv, very informative and quite complicated.
But why? It'll be staying behind your TV, running maybe 1-2m and never be touched so as long as it does it's job it doesn't really matter.
