does anyone elses sub woofer distort at the loudest setting ??
sounds horrible at full volume !
anyone ?
thanks ben
Its a subwoofer in a laptop its hardly going to rattle your teeth
anyone ?
thanks ben
Have i missed something about this discount code??![]()
How do you get the vista 64 bit upgrade?
Plus when applying for the Windows 7 upgrade it says the only option is 32 bit
Well today i brought the Acer 6930 for £600
Specs are,
Intel Core 2 Duo P7450 2.13Ghz 1066 MHz FSB 3mb L2 cache
9600GT NVIDIA 1Gb Dedicated
320 GB SATA
4Gb RAM DDR2
16 inches screen
Windows Vista Home Premium
Great spec for the price just setting up now![]()
Can't say I use bluetooth on my laptop ever. Even if you do you can buy a USB bluetooth for pittance.
Last image loads instantly but the other hang?
No idea about the images sorry, must be image shack problem.
I've heard the keyboard may feel a bit flimsy and cheap? Is that the case you think?
Would these play COD4/5 ok not with all the eye candy on though
