Having had both of the above I've noticed a lot of similarities in the handling.
On a couple of occasions however the E90 has put my heart in my mouth and thinking back - I can't ever remember the E46 doing this. Will try to explain what it's doing:
Going round a sharpish high-ish speed bend, if you come off the throttle - rear end lightens up just a touch - very very subtle, nose tucks in - everything is fine and dandy. Exactly I suppose as you'd expect.
However, do the same bend and come off the throttle onto the brakes and the rear end steps out instantly, sometimes in a big way. Nose tucks in, if driving aids are odd - they ping the rear brakes, if driving aids are not on - you're needing opposite lock otherwise you'll be going agricultural pretty quickly.
The E46 never ever scared you, it was always totally planted under braking.
Either BMW have dialled this into the E90, or only other thing is perhaps I'm running the wrong tyre pressures?
