8GB of 1066mhz on a gigabyte P35-DS4?
19 Aug 2007
Is it possible? I've searched and searched and cannot find confirmation anywhere?
I don't want to overclock the memory. I just want to use 8gb of 1066mhz running at 1066 in a P35-ds4
Anyone here got it working? And if so what brand and bios settings did you use
Thanks.
Thanks, just want to make sure I get the right type.
Are you running it at 1066? And what are your settings/voltages in BIOS?
Sorry for so many questions. I just want it to work.
System Memory Multiplier (SPD): ?(Resulting memory freq - ?)
High Speed DRAM DLL Settings: Option 1
Performance Enhance: Standard
DRAM Timing Selectable (SPD): Manual
CAS Latency Time: ?
DRAM RAS# to CAS# Delay: ?
DRAM RAS# Precharge: ?
Precharge delay(tRAS): ?
ACT to ACT Delay(tRRD): ?
Rank Write to READ Delay: ?
Write To Precharge Delay: ?
Refresh to ACT Delay: ?
Read to Precharge Delay: ?
tRD: ?
tRD Phase Adjustment: ?
DDR2/DDR3 OverVoltage Control: ?
CAS Latency Time: ?
tRD: ?
I'm not sure if I'm running it at 1066, I think I may be running it at 800, as my FSB is 400Mhz here are my settings:
System Memory Multiplier (SPD): 2
DRAM Timing Selectable (SPD): Auto
CAS Latency Time: Auto
DRAM RAS# to CAS# Delay: Auto
DRAM RAS# Precharge: Auto
Precharge delay(tRAS): Auto
ACT to ACT Delay(tRRD): Auto
Rank Write to READ Delay: Auto
Write To Precharge Delay: Auto
Refresh to ACT Delay: Auto
Read to Precharge Delay: Auto
tRD: Auto
tRD Phase Adjustment: Auto
My system, is stable and while I used tweak timings to get a little extra performance I don't have time these days so just stick most things on auto. :)
