Should I use/buy Windows 7?
6 May 2009
I currently use Windows XP and have a 2gb X2 3800+ machine with an 8800GT.
Mainly use the pc for music and videos, a couple of games are installed and i occasionally do some editing in Photoshop 7
Main questions -
Can it be uninstalled/formatted if i dont like it?
Will it support drivers for 8800, audigy 2zs and Nforce motherboard?
Can i upgrade parts without it moaning?
Which chipset is you Motherboard? Via ones of that age don't fair too well. May also have probs with nforce4.
edit: ah i see, nforce. Well it might be OK. I did have problems with older chipsets.
You could always try the RC to see if your hardware is supported and works the way you want it to before you part with any cash.
Thanks. Whats this RC? Just a free, cut down version of it. If so is there a download link or do you have to send off for it or something?
