According to an updated Zotac 9300 ITX manual, available at http://downloads.zotac.com/mediadrivers/mb/man/pa105.pdf, there is a new revision of the Zotac 9300 ITX motherboard, PCB version 03.
The new features are 3 SATA connectors (against 2 in versions 00 and 01, they seem to have skipped verison 02), and an USB power select jumper, which allows wake up on USB. Also, PCB version 3 supports dual link DVI with resolutions up to 2560x1600 (against single link DVI with resolutions up to 1920x1440 in versions 00 and 01).
The bottom side of the version 03 MB should be labelled as 236-DA105-xx30F.
So, Zotac have now taken care of all three omissions one could think of.
