Price Concious - 10/100 PoE Switch w/ Gbit Uplink
13 Jan 2004
As per the subject really, Netgear FS728TP for £370 ish but not a fan of Netgear stuff for enterprise level use.
Any ideas? HP Procurve stuff all starts upwards of 1k.
We use Cisco Catalyst Express 500, 24 port 10/100 PoE ports with 2 copper gig uplinks and can take 2 fibre modules.
We get them for about £800 ish, we have loads of them and run our IP phone system and desktops on them.
Kimbie
Do you absolutely need POE, or is it just for a few WAPs etc? POE injectors, or even a POE patch panel may work out more cost effective
I'd go with Cisco's of some kind myself, as said catalyst express units can be had for <£800 quite easily. That's less than £35 a port which is pretty good and I suspect a fairly small cost compared to the cameras themselves.
I'd also say that generally when you're budgeting the solution you incorporate the cost of the switchport into the unit cost surely? Everywhere I've worked that's been done for everything from servers to desktops and ip phones, eliminates nasty surprises and trying to find network capacity on the cheap...
If you want to save a bit then maybe the Linksys / Cisco Small Business stuff - we're currently looking at a 48 port PoE with 4x Gb uplinks (copper and fibre) for £600
There are 24-port versions available, in fact there's quite a few but some only do half of the ports on PoE and whatnot.
Thanks for the suggestions, had a look at the Cisco SB stuff (Linksys for all purpose and intent) but management has decided to go for the cheapish Netgear.
I've aired my opinions on using a Netgear but hey, on their head be it :p
I've got NetGear FS726TP and FS728TP supporting CCTV cameras on a number of sites - no problems with them at all.
