I know the answer is 'not much' but I'm not hoping for much. I'd like to screw it onto the back of my psu, which uses an 80mm fan. Reviews seem non-existent.
The hope would be for sub 70 degree light load temperatures on an 8800gt (not a problem) and an i7 running as severely undervolted as I can get it to boot at. The benefit would be to have a system with only one fan running for office work and films, which I think is as quiet as I could get the system without using a fanless psu. I'm sure there's some people here from the time before 120mm radiators were the norm
I have the 54mm thick 20 fpi black ice one in mind, probably with 90 degree fittings on it. Nice and restrictive I know, but needs must.
Amazed that I can't find a single review of this. I've emailed hwlabs asking for a graph of delta t against heat dissipation for a range of static pressure fans, may as well ask for the ideal. I wonder if they'll even get back to me. I'm estimating 200W load, but don't know to be honest.
If a single 120mm radiator holds a delta t of 15 degrees (say), and the 80mm radiator has about half the surface area, is it a fair guess that it'll hold a delta t of 30 degrees for the same load? I don't think it's looking very likely that this idea is going to work, I'll be blowing hot air from the psu over the fins for one thing. For another if I ever have the air hotter than the radiator (likely) it's going to make the rest of my loop hotter.
