I think a spec like this would make me upgrade my 40d, seems a coincidence that the day the nikons get announced this comes out:
60D Rumor
Someone claiming to have seen the final proofs for the 60D brochure says these are the specs of the upcoming 60D.
Here are some of the specs:
- sensor seems to be a tweaked version of the current 15MP sensor (better
DR, better high ISO IQ, eliminated pattern banding at high ISO)
- 98%-coverage, 0.96x magnification VF
- 3″, 1150K-pixel, active-matrix, organic LED display (25% higher-res than
current 960K screens)
- 19-pt., all-cross type area AF ellipse (basically, the current 1-series AF
point layout w/o the 26-pt. assist AF pts.; the new 1-series apparently will
have an all-new 45-pt., all-cross type AF module; what limits Canon from
drastically reworking the AF-point layout is the fact that all the currrent
Speedlights have AF-assist beam patterns that are designed only for 7, 9 &
45-pt. AF layouts–they just can’t make a new area AF design or add more AF
pts. that easily because of that).
- 1080p@30fps full HD video with full manual controls and contrast-
detect AF, stereo audio inputs
- 7.4FPS@14-bit mode (CIPA-standard testing method)
- new DiGIC V is more than 2x faster than current DiGICIV, enables
onboard processing of all those DPP functions still not done in-camera
with the current cams (i.e., lateral CA correction, geometric
distortion correction, better highlight & shadow detail extraction,
plus new “Diffraction Elimination” function: pixel-level contrast
enhancement and sharpening to counteract aperture-related diffraction
effects)
- AE microadjustment; +/- 3 EV range with 1/6EV steps; separate saved
corrections for Evaluative, CWA, Partial and Spot metering
- new higher capacity, slightly higher-voltage (to drive the faster
mechanicals & electrical readouts for the higher framerate), chipped
Li-Polymer battery (LP-E7), with new, magnesium-alloy framed BG-E7
battery grip with AF-ON and mini-joystick selector buttons duplicated
- lastly, an all-new, pleasantly surprising “feature” that would bring
a smile to all the Canon loyalists (just watch for it)
			60D Rumor
effects)
