The Ford Focus of Death, Episode I: The Brown Trouser Moment
Wack it into neutral?
Also surly if the power steering cuts out (nver had it happen) then it just makes the steering heavyer to drive but not impossible? Or is there soemthing that really ****s witht he steering so its reall;y really heavy much more then a non power steering car in the first place?
I drive a car with no power steering all the time:D
Well once the pump has stopped working, you're pushing all the fluid around the system as well so it'll feel heavier than a non power steering car.
the faster PAS rack will also make it heavier than a non pas car because of the gearing.
still wouldnt let that make me come to a stop on a motorway
Lack of PAS when doing over 15mph isn't really too much of an issue tbh, yes its got more weight to it than before but its fine, nasty place to brakedown, i was overtaking someone on a back road, half way past and my EPC (Electronic Throttle) light comes on i've now got no power and i'm on the wrong side of the road slowing down.... GREAT!
You're correct on all fronts - it's much heavier to drive, but by no means impossible.
You're essentially having to move the hydraulic ram though, by using the levering force of the steering wheel. It requires a herculean effort to get any more than a quarter of a turn (as the hydraulic pressure builds up), but little corrections around the centre of the steering are relatively normal in terms of effort.
With a non-PAS car, you're just turning the suspension components directly, there's no hydraulic force to overcome, and no extra resistance as you use more steering lock.
You mean PAS racks are higher ratio than non PAS racks?
Afterall thats the benefit of assisting the steering.
This has happened to me a couple times. It's frightnening!
I have a focus also, and it's mainly approaching roundabouts which this happens.
My speedo never cuts out, but you can notice the rev's dropping below idling point which is then followed by cutting out. Quick reset fixes, but it's rather unnerving!
It sounds like you're suffering from a different problem, where the engine revs often drop below idle causing a stall. Get it down to a Ford dealer, apparently they can fix it with an ECU update. Bit more info in this thread.. Hope it helps.
Thanks mate, I'm just about to shoot off to work, will read up on that later. Cheers.
pah whimps
my 2nd car was a VW polo 1.4 without powersteering
you're describing loosing power steering as some kind of major event. Back when men where men we didnt need power steering
you just need bigger arms :D
on a more serious note, hope you get it sorted :)
pah whimps
It's a LOT harder to steer a non funtioning power steering than non power steering.....
My Escort didn't have power steering, the only thing that made it a pain was the fact that the rack was so slow, it took a few fair turns to get from lock to lock.
pah whimps
Please take a moment to learn how the systems differ :)
If you think when your PAS fails it will be like driving a non pas car you're in for a massive shock.
ive had my powersteering cut out on my vectra when the intercooler hose was playing up
caused the airmassmeter to read practically nothing causing the car to stall without warning. Of course when it stalls, the powersteering stalls
even with my big heavy vectra, i still managed to steer it ok. the OP just needs bigger arms :p
pah whimps
I've driven non power steered cars. Vauxhall Nova, an old Citroen and a few others. But like it was said earlier, a non functioning power steering steering wheel is more difficult to turn than a steering wheel with no power steering.
Thats slightly different try the same thing when going less than 15mph and report back.
The Focus does have a problem with faulty speed sensors causing the idle control to fail, so you tend to get engine stalling whilst stopping at junctions etc. However I've never heard of a faulty speed sensor causing an engine to completely cut whilst driving along normally. Personally I'd suspect an electrical fault elsewhere.
did you check the if battery poles are firmly tighten? it could be them , a friend of mine didnt lock them properly and while driving he lost all power too (because one of cables didnt make contact with one of the poles)
Ahh brilliant I'll check them. I do know my poles DO need tightening but I've always forgotton to tighten them. Is it a simple case of spanner and tighten the nut? Thanks! :)
have done. stiutation still the same. Yes its hard, but by no means is it impossible and likely to make you crash. Am i joking about the stronger arms bit to install some humour into this thread ? yes.
stop being an argumentative *"$!
Sounds like a pretty unerving moment you had there op. I would have thought the loss of power steeing at 50mph wouldn't have felt much different though. It's only really noticeable in car parks and such.
