High End GFX with native hdmi?
19 Dec 2003
Belfast, N. Ireland
I've been looking around for a high end ATI Gfx Card that has native hdmi.
Looking for something to last me a long time which will perform well at 1920x1200
Mainly going to be used for COD4 and then Modern Warfare 2 when its out.
I've found the Palit Radeon HD 4870 X2 2GB DDR5 Revolution 700 Deluxe after sometime of googling.
Im just really looking for some more options as i dont like the tri-slot system of the Plait.
Any advice would be great,
Thanks.
Thanks.
I had a palit 4870 1gb that had dvi, vga, hdmi and dp connections and was a dual slot design
Baplad, two of these if you've got a crossfire capable mobo...
I/O Output: Display Port+HDMI+DL-DVI+VGA
Core Clock: 870 MHz
Memory Clock: 1050 MHz (4.2Ghz!)
PCI Express 2.0 x16 bus interface
1024MB /256bit GDDR5 memory interface
Dual Slot Vapor-X Cooler
HDMI compliant via dongle
7.1 Audio Channel Support
Microsoft® DirectX® 10.1 support
Shader Model 4.1 support
It's got Displayport and HDMI ports as well although it's still a case of only 2 out of any of the 4 outputs can be used at a given time. You can have something plugged into all 4 ports but you will only get an image out of 2 that you choose via CCC.
Here's some reviews...
http://www.overclockersclub.com/reviews/sapphire_hd4890_toxic_vaporx/
http://www.bigbruin.com/content/sapphirehd4890_1
http://www.neoseeker.com/Articles/Hardware/Reviews/sapphirehd4890vaporx/
Was looking at the 4850x2 but ive seen a whole number of people talking about how loud the cooler is on it.
I've seen some customized cooling with people adding 2 zalman VF900's to it, but the card at load goes to some scary temps.
