AMD Phenom II X4 955
If your going to be doing any overclocking and multiGPU gaming then:
Q9550 - LGA775 isn't coming to the end of line til atleast 2011 now.
Otherwise if you plan on running stock and doing single GPU gaming get the PII 955.
Drop this Muili GPU gaming then you must use an Intel crusade that you have taken up.
Oh & i'm allowed to overclock my AMD CPU as well.
Oh I dunno...
AMD Phenom II X4 940BE @ 3.00Gig - running faster RAM
Q6600 @ 3.00Gig
2x 260GTX @ 625/1296/2200 in SLI running lost coast benchmark at 1680x1050 x16 AF x16 FSAA, all settings max - identical nVidia control panel settings on each setup...
AMD Average over 3 runs 146.97
Intel Average over 3 runs 179.15
OK its just one game, but the source engine is traditionally a good example of a CPU limited game.
End of the day if your serious about running a high end multi GPU setup then intel is going to be making better use of that system.
Thanks guys. I already have a Q9450 on my main machine and want to build another for playing around with virtualisation. So I can get either another 9450/6600 or go for the 955BE. It looks like the 955 seems to get peoples vote. I would prefer to run this on DDR2 because I have a spare 8gb - will the 955 run ok on AM2+?
more tests at 2.66 v 3.2 lol... come on... and even then look at the CPU results in vantage... in non single thread the AMD gets pummeled even with the clock speed advantage.
What are you on? they clearly (and the performance difference scaling shows) that the intel is running at stock 2.66 without turbo.
Vantage is not a game... but I suggest you take a look at the DX11 spec multi threading support throughout the pipeline both CPU and GPU, also many games coming out soon and even some out now can use render threading to boost performance. ETQW sees a 30% performance boost enabling it on a quad core and approx 60% on i7.
The results only matter if they are relevant... yes intel has the advantage in single thread... clock for clock...
