it's a bloody palace![]()
not yet but it will be when its done, I will also have one hell of a mortgage and be completely broke
EDIT we are going to put floor to ceiling doors that open on both the living room and dining room
no problem.
I do have a question.
The internal cavity walls have lots of crap in them, ie builders rubbish and stuff. Is this going to be a problem?
Exactly how much stuff? Ideally the cavity should be empty and it might become a problem if you later decide to fill it with insulation.
The main problem is that the cavity is there as the best defence for damp as water cannot cross a void. If its full of rubbish then it can and defeats its sole purpose.
See here for more info
http://www.diydoctor.org.uk/projects/cavities,cavity trays, lintels and insulation.htm
They are not full but the there is a reasonable amount at the bottom of the walls.
They are all internal walls so I assume damp will not be a problem. Also I am on the 4 th floor.
knocked bathroom & separate toilet into one.
Dont take it on if you havent done anything like it before.
Lounge after (ignore the pool, we're about to have a sprog and going for a water birth at home!):
Here's the pics of our house refurb
if you need an idea of what to expect regarding costs, let me know as I've still got the details.
That's a bit catch 22
I have quite a few freinds with varied expertise that will help - electricians, plumbers, builders, decorators, even gardeners![]()
If you are getting a survey, make sure you discuss exactly what you are getting, and whats excluded. Ask to see an example of their report. A full building survey (what used to be known as structural suvey) will set you back over £600. (in my opinion worth it). Any other survey will be somewhat superficial / limited.
But, don't panic if it comes back with missing DPC or failed wall ties, etc, etc. The majority of defects are straightforward to fix (although this way you can budget for their repair).
For a light touch refurb you are looking at £400/m2. For a refurb extending to re-wire, new heating, and allowance for either fabric or roof repairs, and all new finishes to a high standard, etc, you are looking at £1500/m2.
