- 29 Jul 2007
- cornwall
can any one tell me what is the best psu to power 2 4870x2 in crossfire
Dont get less than a 1000 watter.My enermax galaxy would do or any other top brand 1000 + watts. http://www.guru3d.com/article/radeon-hd-4870-x2-review-crossfire/6
I cant comment on the technical aspect, but I can confirm from personal experience that my rig will not work with 2x4870x2s and an Enermax 720W PSU
It runs fine with a 1000W Corsair![]()
If the op wants to run h2o and half a dozen HDs and lots of fans ect it pays to have power in hand.Running a psu balls to the wall 24/7 is not something id recommend.My enermax galaxy is also 85% efficient.I prefer to work out what i need and get a extra couple o hundred watts extra.
Have you run two 4870 x2s with a tagan 800 watter gareth ? TB said Enermax Liberty 720W fails where the COrsair HX1000 works with his cards.Guru measured the power as 740 watts with a air cooled core duo.Most likely the op will run quad overclocked and maybe h20.If you measure and it uses 750 to 800 watts draw then i dont think telling the op to buy a 800 watter is good advice.If it does run with a 800 then it will be running flatout or close to all the time its under load.When building a pc you should never ever skimp on the psu as that is the most common cause of pc problems.If the op is spending the money to buy top performance gfx cards why risk ruining the performance for the sake of saving a few quid on the psu.Also every year the power needed for new cards increases so a good psu with power in reserve is a good investment.If you were buying a car and wanted one to do 70 mph alday on the motorway you wouldnt buy a car with a top speed of 75 would you.
