I've used patch cables for everything. I view cross-over cables as just NIC to NIC with no router inbetween.
I would use a crossover between a ps3 and a router, simply because you use crossover cables for like devices. switch to switch, pc to pc, pc to router etc... all require crossover (even if you use a straight through cable, the auto-MDIX will perform a crossover inside the device itself).
As has been said though, it doesn't realy matter, all modern devices can auto detect the cable type and adjust accordingly.
Er, you mean a normal patch cable? A router and a PS3 arent like devices . . . .![]()
This would be correct with an old school single port router. But since all domestic routers now have built in switches you'd use a straight through cable. Which is what you use in 99% of situations.
