well my Lian arrived this morning
but the fans haven't....maybe later or tomorrow.
well, it looks great from the outside; it's got a lovely brushed aluminium finish...... and it looks great on the inside too.
BUT, the front panel stack of removable grilles, attach ONLY to the internal panels, so these panels cant be removed
but the lower HDD CAGE comes out easily, leaving 2 horizontal panels that i can attach the fans too; so it'll still ventilate very well
..the stock fans are rubbish...so dump them..enough said!
you have to be very careful working inside it... the Ally is very delicate and marks very easily, it is also way too thin.... the case rattles quite a lot, especially the rear panel PCI spare slots
....... but i can correct all of this.........the internal panels look like about 0.6 mm and the outside panels about 1mm.....not sure........but these are way too thin, i'd have made these in 2mm all over....or even 3mm, because this case is as light as a feather and could easily be 4 times heavier and still be ok.
i would say internally, that it's not as good as my Thermaltake Armour, (the quality isn't as good) but it's a much nicer looking case.
i therefore cant mod it very much, ..... it's not strong enough, i dont even trust removing the side panels, they dont come off easily.....i'll be leaving mine off until i've finished it next July.... i'll just have to be bloody careful wont i !
but these faults i can live with.....because this case redeems itself by the fact that it looks so damned good on the outside
