pug 205 electrics..
my sister has a 205 and it failed its MOT on bulbs
and exhaust
she's replaced the bulbs and the back box, but main beam doesn't stay on.
she's not sure whether the car failed because the main beam didn't work at all, or if it failed because it doesn't stay on, because she didn't test the bulbs before the MOT (i told her to, but she said she all her flatmates were out and she couldn't test it herself..)
anyway, main beam doesn't stay on, and it doesn't work when dipped beam is on.
sidelights are fine and the dipped beam is fine. main beam works fine when flashing when the headlights are off, but the main beam doesn't work at all when the headlights are switched on - it doesn't work on flash and it doesn't hold
a brief google found some forum with the same problem.
http://www.howtomendit.com/answers.php?id=130119
how does one go about fixing this? replace the stalk, or is there more to it?
also, can you fail an MOT for not being able to have main beams held on?
cheers
oh, she also had advisories for an oil leak, corroded brake hoses, old and cracked tyres and a nail in the rear tyre(!)
i presume this isn't lethal, but should the brake hoses be fixed?
cheers
