Which whey protein?
7 Sep 2008
So which whey protein do you all have?
I've been looking on the myprotein site for days but unsure about which one and which flavour to get what one shall I get?
Again, Impact - just about to order it. Hatter why do you specify unflavoured? Is there any difference in qulaity of the flavoured?
Impact Whey Unflavoured
I wouldn't go for chocolate, it makes me gag, it's so sweet. And considering you're going to be downing it in seconds, does it really matter what it tastes like. Save yourself near £10 and go for unflavoured
On the main site use "www.sports-nutrition.net " on the Price Matcher at the bottom, gets you 10lbs for £28, absolute bargain
MP68619 for a further 5% discount if it's your first purchase
unflavored yuk that taste rank though.
don't any of you unflavored lot mix something in to make it taste better?
i went through the unflavoured stuff for a long time....got absolutely sick of it...and it tastes crap with not so good milk or water. Now I buy the bulk flavoured stuff from MP...im on choco smooth just now..and its far beter than the chocolate. Its a bit more expensive than the unflavoured but by the time I bought chocolate drinking powder to flavour it and hastle of actually doing it every time....£10 is nowt :)
http://www.myprotein.co.uk/bulk-supplies/flavoured-protein/impact-blend/
also the belnd contains whey isolate also..so its maybe slightly beter
Ah...I see they dont have the chocolate now....just choco smooth. It was boggingly sweet anyway :D
I've bee meaining to use MyProtein.co.uk for some time but they have so many products I;m not sure whay they all are and the differences.
Under Protein Powders they have:
Impact Blend
Impact Whey Protein Undenaturated
Impact Whey Protein
Calcium Caseinate
Hydrolised Whey Protein
Acid Whey Protein
Egg Whites Powder
Impact Milk Isolate
Impact Whey Isolate
Pepto pro
Egg White Powder
Instant Milk Protein
Organic Hemp Protein
Pea Protein Isolate
Whole Egg Powder
Soy Protein Isolate
Then under Bulk Supplies they only have:
Impact Blend
Isolated (refill)
Erm...which one do I want? I just want basic protein/whey powder with a choc flavour in bulk preferably for as cheap as possible. I used to use Reflex and it tasted fine. I can't drink maximuscle cyclone or I'll vom.
get the cheapest, or, do the price match as it usually shows what options you can get for a reduced cost, as recommended above try thr price match first, if nothings there then the impact whey protein, its listed as something like £17ish for 5lbs, 30ish for the 10lbs option though the price matching should knock a couple quid off that.
I'd order a smaller amount, I'm(i think) slightly lactose intolerant and the isolate(which has less lactose and is basically more filtered) version which is quite a bit more expensive, leaves me feeling less phlegmy and mank after it, I also get that way when I drink milk. But even so I'd recommend a smaller purchase to start you off on the off chance you can't stand it.
I use cheap flavourings myself for the stuff, cocoa powder is cheap(2-3 quid for a quality tub of the best stuff and will do 100's of shakes) and a cheapo pack of sucralose and I'm sorted, add's 2-3p to the price of a shake probably. Loads of people use nesquik though you're essentially just adding sugar, which may or may not be a problem for you.
Impact Blend
Impact Whey Protein
Calcium Caseinate
Acid Whey Protein
Egg Whites Powder
Impact Milk Isolate
Impact Whey Isolate
Pepto pro
Egg White Powder
Pea Protein Isolate
Whole Egg Powder
Soy Protein Isolate
Impact Blend
Isolated (refill)
lol it gets so confusing when you see so many types
but I think I'm going to opt for the impact whey protein myself only because I've used it in the past before.
I've been using Impact blend for a while, and its great, but been reading up about taking protein from other sources and not just pure whey, so trying out the MP Max XS tub...see how that is, with EXTRA FLAX! :D
Yeh, choc nutrisport is superb. I was taking unflavoured for a long time and then discovered this little gem of 5kg blend for 39.99 :D
