ST220 on an 03 plate.....how much?
28 Jul 2003
South Wales
Looking at buying an st220 on an 03 plate.....6speed box so it's a facelift (i believe some older ones came with a 5 speed?)
what would be a good price to pay? it's got 68k on the clock and a good service history.
Sure its a facelift?
I'm sure the facelift was 2004 so the earliest ones were 53 reg - if you've seen it or have photos it's immediately obvious from the dashboard
Lol it wasnt recently - March 08 and was very low mileage.
Same with any cars though, best not to think about what you loose in depreciation...
I dont think the improvement is as much as you'll see on a turbocharged car
Can't imagine you'll need it though!
I know that in some circumstances it can improve performance while helping MPG.....and i'm not worried about the MPG but every little helps! (oh, and the extra performance too lol)
can this be right? not bad!????
Bluefin for Ford Mondeo ST220 3.0 222bhp 2002+ £295.00
Click to enlarge
Increase power from 222bhp to 246bhp. Increase torque from 280Nm to 294Nm (Increase of 10ft/lbs). Bring your car alive and maximise the performance of your vehicle. No mechanical or technical skills required. Just simply plug-in and go. With more than 500,000 cars Superchipped, we have over 27 years experience in improving vehicle performance. Unit is easily installed from the comfort of your driving seat. Simply plug the bluefin handset into the diagnostic port (connecting you to the vehicle’s Electronic Control Unit), the bluefin then uploads new settings to enhance your vehicle's performance bringing your car alive within minutes. bluefin is designed by Superchips Ltd – the UK market leader in engine performance improvement.You can be confident that bluefin will dramatically improve your vehicle's performance. The product is covered by a 7 day refund, a lifetime product guarantee, and supplementary vehicle warranty. The unit can also be used to return your vehicle to its original settings, also as a diagnostic tool to find faults on your vehicle, and as an immobiliser/re-mobiliser. Superchips are the official tuning partner of Volkswagon Racing so do not trust your car to anyone else.
Solid has a Dreamscience on his ST220 - hopefully he'll see this thread and let you know what he thinks :)
Sod that.
I would say if its pre facelift it would be worth 4k at max and be wary of gearbox/clutch/dmf issues if its a facelift might go up to 4700 or so depending on condition.
I actually have had both bluefin and dreamscience on my car, the dreamscience is a notably better map with a lot more customisation and the fact you can use it on more than one car as it has 5 unlocks. the map provides much cleaner revs and seems to have that ability to rev and more power available lower down than the bluefin. If you got the cash get the Dreamscience unit. Much better imo. BHP/Torque increase isn't fantastic but it never will be with most NA engines, just gives you better/more usable power through the rev range. Makes me sad I paid 8.5k for my 04 plate just 18months ago :(
what did the dreamscience kit set you back? any other mods required to get to the figures you have in your signature?
I got a good deal and got it for £300 brand new but you wont find them for that anymore.
The other mods on the car are a Mongoose Catback exhaust and at the time I was running a K&N 57i cone filter. But now I have a pipercross VIS kit on, to be honest modding wise won't get you too far with this car, the filter and exhaust make the car sound even better at both ends but probably don't do too much. Better off saving your cash unless you get a good second hand deal on the bits.
I have upgraded the brakes though to the focus ST items on the front and that is a mod I would definitely recommend. The standard brakes are woeful.
