Iphone newbie, after some advice about importing pics
8 Sep 2006
uk
Hi all,
On my pc I have various folders full of photos, and I want to transfer a few different ones from each folder into a new folder on my Iphone.
Do I have to create a new folder on my pc and copy the ones I want into that then sync that folder using Itunes, or is there a way I can just browse the folders then pick the ones I want to import?
Any help/advice appreciated:)
Hi all,
I think you chose a folder to import (or folders).
Shame you don't have a Mac as it is much easier thanks to iPhoto!
I would create a new folder on PC and copy the photos you want into there, then sync it. add more photos as and when you want and it should keep syncing.
Seems silly having duplicates but whats a few GB these days
Does this create a separate folder on the phone itself? Currently I only have 'Camera Roll', but I would like to import all my photography under a new folder called....you guessed it...'Photography'.
Can you move photos between folders on the phone itself?
