I'm in need of a new case. I'm not fussed about the looks because it will be in the loft out of sight. The box will be used for backing up other boxes on the network, small amount of personal storage and as a file server used to stream to the 5 media boxes around the house.
A couple of must haves;
Minimum space to install 12 hdds (I will not be installing any optical drives)
Ability to take my sas card (its 32cm long)
I'm a long standing Lian-Li fan, but would consider other brands if they fit the bill. The A70 and P50 look promising.
With this in mind I have a budget of say £160.
What would you lot suggest?
