- 6 Jun 2009
- Colindale, London
Which way should the Titan Face, air blowing into or out of?
CheersThat stuff will workThis mainly due to the offer, guess i should really check with you guys first this timeCheers
, oh well, ill learn from the mistake(s) lol
RIGHT, the new DDR3 RAM is here. Wooo, back to the build![]()
no trust me DDR3, been through all this.
Right, im trying to put the case wires onto motherboard.
Power SW for example, now in the MB manual it shows which way round the switch should go (PW- and PW+) but on the actual cable, the two are just labeled with an upwards facing arrow and the letter G. Which way should i put it on?
Cheers
I thought AMD setups don't utilise DDR3 only DDR2?
AM3 based cpu's can use DDR2 or DDR3 but they need different motheboards. All the AM3 socket motherboards support DDR3, but when you put a AM3 cpu into a AM2+ socket you can only use DDR2.
Perhaps you're thinking of triple channel which only i7s use, whereas AMD setups only use Dual Channel (for now)?..
As was said above, AM3 motherboards are all about DDR3![]()
