Tuniq Annouces Tower 120 Extreme CPU Cooler
7 May 2006
London, Ealing
Tuniq today announced its newest CPU cooler, the Tower 120 Extreme. With this release Tuniq introduced what it calls a radical design change, that increases heat dissipation surface area, and brings about turbulence that helps cooling. To do so, each aluminum fin has "wave-design" edges on two sides. Every neighbouring fin has an alternating wave-pattern, that helps provide turbulence. A 120 mm, PWM-controlled, LED-lit fan is nested inside the fin block, that circulates air. Five nickel-plated copper heatpipes convey heat to the fins, which make direct contact to the CPU at the block.
The cooler measures 131(L) x 112.31(W) x 150.7(H), and weighs in at 775 g without the fan (around 850 g with it). The fan spins at speeds between 1000~2000 rpm, pushing up to 90.65 CFM of air, with a maximum noise output of 20 dBA. Out of the five heatpipes, three are 8 mm in thickness, and two 6 mm ones. The package includes a 1g tube of Tuniq's recently announced TX-3 thermal compound. In Tuniq's own tests, the Tower 120 Extreme emerged at least 10% more efficient at cooling than its predecessor, the Tower 120. It is compatible with most current CPU sockets, including LGA-1366, LGA-775, and AM3/AM2+/AM2. Expect it to be priced close to that of the Tower 120 when it hits stores soon.
Pics
TECHPOWERUP
Looks interesting, particularly the 1000-2000 rpm pwm fan, pretty hard to find pwm fans that run at those sort of speeds.
Looks cool, I have a tuniq tower (an old one before the "LED" version which I think is the exact same, just doesnt have a fan with LEDs).
Interesting to see they have changed to direct contact with the heat pipes and the cpu. Perhaps its better? The current tuniq has a block of metal in contact with the CPU with the heatpips going into it.
Will be interesting too see how it compares to the upcoming 140mm fan next gen heatsinks :)
It would have been better if it had a 140mm fan ;)
ocuk have it on pre order now, hmmm, might try one
http://www.overclockers.co.uk/showproduct.php?prodid=HS-001-TQ&groupid=701&catid=57&subcat=
Yeah the TX-3 is a good plus point. I'm sure it will be popular at that price though considering you don't have to buy another fan.
I would like to know how tall it is compared to the titan fenrir, as the titan stops me having my side fan fitted in my Antec 902 case
Tower 120 Extreme Specifications
Dimensions(mm) 131(L) × 112.31(W) × 150.7(H)
Titan
Size (with fan): 107mm (W) x 124mm (D) x 156mm (H)
SO the 120Ex is slightly smaller. (as in height)
Moe competition can only be good. But I must say it looks a little like recent thermaltake coolers.
That fan spec though... yea right. :o
moot point if they havent revised their mounting system, was so annoying to fit, admitedly cant compare it to a TRUE etc as i went to a noctua afterwards
I will be interesting to see this review first to compare with H50 and Prolimatech but I think this Tuniq won't be performance well under 4Ghz with i7 core.
Thought the TX-3 thermal paste is very good indeed, does ocuk will have in stock for TX-3 thermal paste seperator ?
