Permabanned
- 15 Dec 2008
Hey guys, I run some tests on another forum between running in x8 and x16 mode to see what effect it had on modern games, It's nothing special but thought some of you might be interested in the results.
The GPU is a 4890 and my CPU is a 4.2Ghz Pentium Dual Core E6300
It's not the most accurate or controlled but it gives you an idea.
Do note that I only have 2Gb of RAM because one of my sticks died.
Because of this frame rates are lower then normal because of a lack of system RAM.
Anyway, results are mixed
Crysis, x16, No texture Packs :
Crysis, x8, No texture Packs :
Those looking close will see that the x8 con fig has a higher minimum frame rate then the x16 con fig, That's because I restarted windows so it had a bit more System RAM free.
Crysis, x16, With Rygels Texture pack :
Crysis, x8, With Rygels Texture pack :
The minimum frame rate took a hit when running in x8 mode, this is due to the texture pack requiring more then 1Gb of VRAM and having to send quite abit of data over the limit x8 connection. Still not as big of a hit as I was expecting.
STALKER : Clear Sky, x16 :
STALKER : Clear Sky, x8 :
I was expecting more of a difference then that. Especially with these 2 titles as they are the most demanding games available at the moment.
Mind you, I do run Clear Sky with a texture pack that I couldn't get to load in the Clear Sky benchmark, Maybe that would have put extra stress on the VRAM and made a difference to the results?
I also wonder if my low resolution has anything to do with it?
So basically if you have enough VRAM to handle the games you play then you should be fine with x8x8 BUT if you play VRAM heavy games then you might see a performance drop.
People with 512mb cards beware.
