Hi.
In an effort to improve my internet speeds to former glories (3.5mbps), ive just lent a Draytek 2600+ to temporarily replace my Linksys WAG354G.
Upto now, touch wood, im getting better line stats:
Now, my question is, do i go with the WAG354G, the Vigor 2600+ or my mates Netgear DG834N?
Which is the better out of the 3 for ADSL usage?
And will i see any benefits moving from my current non-LLU ISP (Zen) to a LLU based one (O2) in regards to speed or would it be a pointless exercise?
Thanks in advance all.
Not the best sync speed ive seen, but still better than the WAG354G is doing at the moment.> adsl status
--------------------------- ATU-R Info (annex A) ----------------------------
Running Mode : G.DMT State : SHOWTIME
DS Actual Rate : 2112000 bps US Actual Rate : 448000 bps
DS maximum Rate : 2656000 bps US maximum Rate : 768000 bps
DS Path Mode : Interleave US Path Mode : Interleave
NE Current Attenuation : 53.0 dB Cur SNR Margin : 14.0 dB
DS actual PSDM(C) : 00000007 US actual PSDM(R) : 00002769
ADSL Firmware Version : 41e2be2c
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 31.5 dB Far SNR Margin : 14.0 dB
CO ITU Version[0] : 000f414c CO ITU Version[1] : 43420000
DSLAM CHIPSET VENDOR : < Alcatel >
INTL, DSTREAM bytes/depth= 8, symbols/codewords = 0, latency= 0*0.25ms.
, USTREAM bytes/depth= 2, symbols/codewords = 0, latency= 0*0.25ms.
CODE, DSTREAM fast parity bytes= 0, fast codeword= 0.
DSTREAM intl parity bytes= 12, intl codeword= 146.
CODE, USTREAM fast parity bytes= 0, fast codeword= 0.
USTREAM intl parity bytes= 16, intl codeword= 136.
Setting>>
FDQ : Enable, TCM : Enable, EC : Disable, Framing Mode : 3.
Running>>
FDQ : In Use, TCM : Off, EC : Off.
DS : Framing Mode 3, US : Framing Mode 3.
ADI ADSL Firmware Version: 41e2be2c
