Is it worth getting Samsung series 6 over series 5?
4 Jan 2004
¯\_(ツ)_/¯
I'm after a 32" screen, and have seen both series 5 & 6 screens for around £350, both 1080p.
The 5 series is around £50 cheaper, is it worth paying the extra for the 6 series as I have no idea what the differences are!
Probably not at that size. Main difference will probably be contrast ratios, not sure I'd be too fussed at that size. I'd rather have a 37" 5 than a 32" 6, if that's an option :)
I think I may go for the 5 series then., I'm really after a 32" as I'm planning to use it as a PC monitor mainly so a 37" would be a little big. :)
MikeHunt79 were can you get Samsung series 6 32" screen for £350 the best price i could find is about £800
tell me please
thanks
2nd hand if you look around, they may be closer to £400 or £450 depending on how lucky you are. £800 is way to much, you could get a 46" for not much more than that!
