Caporegime
- 11 Mar 2005
- Leafy Cheshire
Over the weekend i've managed to get myself into the situation of needing to remove both my front hubs so i can put the arms in our pillar drill and get rid of the top control arm pinch bolts (Stupid German Design).
I've been thinking about buying an impact wrench to make removing the Hex hub nuts a bit easier, not really got space at the moment to buy a good sized compressor so was thinking about an electric one:
http://www.machinemart.co.uk/shop/product/details/clarke-cew1000-electric-impact-wrench
http://www.machinemart.co.uk/shop/product/details/cis126h-6pce-1-2in-impact-hex-key-set
A 230V 440NM Impact gun should be good enough to remove a Hub Nut thats only torqued up to 270NM shouldn't it?
Any other ideas, i've already got a breaker bar that i can slide a pole over but after looking at several snapped bars i feel impact is the way forward.
