Some new toys...bit of a story with it
Man of Honour
Man of Honour
23 Dec 2002
London
Some of you might remember that about a year ago I bought a Thule AV processor to replace my aging Yam E800. It was a bit of an impulse purchase, but has proven to be a brilliant piece of kit as it's a great pre-amp, has the capability to act as a high quality stereo DAC and then throws in 5.1 compatibility with DPL, DD and DTS. Here's a quick pic:
Of course with time comes itchy feet, so I've spent a little while researching potential options that would also allow compatibility with HD audio from my PS3. The most obvious solution is the Audiolab 8000AP, which is well regarded by many on AVForums. Unfortunately I've also read of some potential issues with phantom centre channels on some audio formats, and still had a niggling doubt about the fact that it is still after all a "mid range" piece of kit from a manufacturer who's gear has always left me underwhelmed in other dem's I've had over the years.
Excluding the Audiolab and some other Japanese yawny gear, there's not many other high end processors capable of dealing with HD audio from HDMI. Lexicon make the MC12, but it's bonkers money, and has it's own war stories. Classe have something, but that's also as expensive as our car.
Then I looked at a legacy processor with 5.1 analogue in. It's an interesting idea and if the seller had been more negotiable, I would have bought a Bryston SP1.7. Unfortunately there's a serious issue with using analogue in, i.e. (a) I'd need a new BD player (additional cost) and (b) you'd be relying on the analogue output stages of the BD player. Most analogue stages are really not a high priority item from a sound quality perspective, and the impression I was getting from reading around was that some older/high quality legacy processors running standard DD/DTS were able to get very close to HD audio from a cheapy BD player.
So in the end I took the easy route and added a Meridian 568.2 to my system. If you read around, Meridian are rated as making about the best kit available in it's area of expertise and whilst the 568 is getting on a bit, I'm told that the newer kit really hasn't moved the game on very much in sound quality terms. It's a legacy bit of kit with some definite pros and cons, i.e.
- Being a legacy unit, it doesn't support HDMI inputs. Making up for that, does have the usual DPL, DPL2, DD and DTS, then adds on better versions of each of those, including THX versions.
- It's designed as a digital piece of kit, to the point that it digitises all the analogue inputs before doing whatever it does with it's multiple processors. So personally, I wouldn't touch one with a bargepole if I intended to use it with a vinyl source. As it is, that's fine by me, as I only have digital sources.
- No 5.1 analogue inputs. See my thoughts about on options like using an Oppo BD83 to put analogue HD audio in. At the moment, I'm not really convinced that this is a big deal. 90% of my use is with music, TV or SD-DVD, and I can live with coreDTS/DD for the 10% of BD's that I watch.
- It does now have the option to add HDMI inputs, but it's LOT of dosh. Meridian now offer something called a HD621, which sits between a BD player and any of their processors from 568.2mm upwards. My processor would need an MHR card (about £440) plus the HD621 (£1500). So in short, it's a lot of wonga, but apparently is the absolute dogs danglies and if I ever have any money ever again (don't ask), might be an interesting present to myself.
- No room correction. This was added in the G series versions (eg. G68). Can't say I really miss this. I've used room correction before, it IMO it was never without some type of audio compromise, so I'd rather not use it if possible.
- Very cool setup option. If you find setting it up a bit fiddly by the front panel, it can be connected to a laptop using an RS232 to USB cable and a free Meridian setup application. This allows very easy naming of inputs, choice of input source (e.g. digital coax 2), choice of presets, defining of frequency cut off points etc. If only all processors were so easy to deal with.
- Some interesting connection options including the usual 7.1 RCA/phono analogue outputs, balanced outputs for the front 3 channels (something I now love using), digital speaker outputs for if you have active digital speakers with their own dedicated DACs. There's not many of those around, but clearly Meridian make them and I believe AVI have some too that might be compatible.
Here's a standard pic that I found on the net of a 568. Haven't taken any shots yet and mine is also mostly hidden in the Quadraspire rack that it's sat on:
So, what's it sound like?
Out of the bag, on music pretty much indistinguishable to my SB+ (Squeezebox+) feeding the Thule processor. Hmmm, I was hoping for bigger things on that. Guess it shows just how good the Thule was. The good news is that on movies there's a definite improvement, and it does offer new surround options like DPL2 THX, which certainly improves TV. A lot of Meridian users rave about "Trifield", which adds a small measure of surround "ambience" to music. Tried it, went straight back to "direct" mode.
I'd also read that the Meridian really didn't care how good the digital source was. That's a new one on me, as every DAC I've played with previously usually sounded better with an improved digital transport, and was the reason I'd ended up with the SB+ (SB3 on steroids). So I bought a s/h SB3 to give it a try, and sure enough, the people in question weren't giving me BS. Really did sound just as good.
That allowed two key things, firstly the sale of the SB+, meaning that the 568.2 was going to cost me nothing (a good thing at the moment), secondly it freed up both a rather good aftermarket power cable and set of stillpoints. I know some people are happy to make blanket statments that this kind of voodoo doesn't work, and with some kit I'd agree. For whatever reason, every previous bit of Meridian kit I've owned (a couple of DACs and a transport) always sounded better with the right ancillaries, and sure enough so did the 568.2.
Apologies for the waffle, but thought some might be interested in a few bits of the detail.
So in short, the Thule is up for sale, the SB+ has already left the building, and they've been replaced by a bog standard SB3 and the 568.2. With the freeing up of ancillaries the result is something that's better on music and lots better on movies. Longer term with 568.2 also has some interesting upgrade options (although they are bonkersly expensive). Big thumbs up from me.
Hi Mr_S..... Interesting story, if I read between the lines, seems we both could be in a similar situation !!!!..... Not started to rearrange my HiFi yet, but have sold off a lot of Contax camera kit..... :( ..... Anyway chance to enjoy the summer !!!!
Well I can confirm your fears about the analogue HD output of basic BD players....no use to anyone with a half decent "legacy" amp from a "HiFi" manufacture..... DD/DTS at full bit rate from a BD player into my Linn Kinos is good enough for any film use I have....Still blows away any cinema or iMax sound system I have visited. (and any other system come to think of it ..LOL)
On a film I don't think I would notice any further improvement, so my interest in that direction is closed for now.
Can we ask how much those 568's go for ? ......... Digitise every input !!!! ... Hmmm 9d runs a mile...LOL ) ... ;)
Reading between the lines is easy, I was just another statistic of the credit crunch and have still not found my way back into the kind of job role I normally do. At the moment, in a fairly naff temp role, which pays the bills, but nothing more.
There's a variety of 568s. The 568.1 can be had from around £500. I've read that the 568.2 is quite a bit better, mine was £800. The MHR card versions are typically around £1k, but all they bring to the party is the Meridian Hi-Res interface card. Useful if you want to connect to either an older MHR capable Meridian DVD player, or the new HD621. Has no other benefit.
As mentioned, if you have any analogue sources that you take seriously, I really can't recommend the 568, so it really couldn't take advantage of your DS Akurate. What I'm not sure about is how it would compare to the analogue output from a DS like yours. My old Thule was on par with a DS Majik, and the 568 is clearly better. So it might not be that far adrift of the DS Akurate.
Of course it does have a different presentation style Linn kit, with more "flesh" on the notes. That's more a question of system synergy and personal preference. My speakers are fairly forward, so something that's the "refined" side of average is a good thing for me.
One thing that might be worth looking into more closely are the re-encoding BD players. Some Samsung units and the new Oppo have the functionality. As I understand it, if they find a HD audio track, their is an option to downsample it to max-bitrate DTS (i.e. the full 1.5Mbps) and output that via SPDIF for use in legacy processors. In theory sounds like a great idea. Must get around to borrowing something to prove if it's worth the effort one day. The Sammy BDP1600 is available for £130 from a well known cheap hi-fi supplier, so might be worth a punt.
Hope your hunt is proving more successful than mine. If you're bored and in London sometime, come and have a coffee.
You don't know how hard it was not to write "you should have bought Linn" ;).... but I managed, for you only to make the comparison unprompted..... pmsl
Truth is I never compared Meridian direct to Linn, (plus a Linn amp would have cost you more, my Kinos goes for over 2K used still)..... The Linn Sound has changed over the years ;).,.... And now most of the range is getting an upgrade, a new internal power supply has been announced for most items, plus the DS range is now getting a software upgrade. So looking forward to having a double boost to my Akurate DS.... which is already a good step on from a Majik DS.
Well I just use the Sharp BD player I picked up for 100 quid, and pick HD sound on the disc menu and it gives me DD or DTS out over the SP/DIF. Straight into the Kinos DAC's. Hopefully at 1.5Mbps, but who knows !
Yeah getting bored/frustrated at times....being another victim of the "crunch".... having my expat contract cut short did cost them though ;) ..... Just need a new job before I can spend it on some new toys....(Klimax range maybe...:D.
I could be in London in a few weeks time for an interview....I'll PM if it happens
Cool, do keep me posted mate, and good luck with the interview. Forgotten how many I've been too now.
I believe that only some Samsung BDPs and the new Oppo BD83 have re-encoding to max bitrate DTS. As I understand it, the older ones will give you DD, DTS, or 2 channel LPCM depending upon what's on the disk. Must try to borrow one of those Samsung units to see if it's worth the effort.
You started out looking for something that would handle HD audio...and didn't get anything that does?
Also;
You mean just like every other digital signal processor, ever.
Also; You mean just like every other digital signal processor, ever.
Yep, failed miserably on my the initial plan, can't say that I'm too bothered though. As already mentioned, can't be more than 10% of my watching that would make use of HD audio capability. So I'm making the absolute best out of 90% of what I watch and listen to, and do a reasonable job on the last 10%.
The reason for me writing such a long text was to hopefully put across some of the thought process that I went through. i.e. started with a plan to add HD audio capability, checked the options, didn't like what I saw, considered legacy processors with 5.1 passthrough, discounted those too, went for a unit that is considered to be amongst some of the best out there that does have a potential upgrade route.
I'm guessing that there's a number of other people who are in the position that I was, might like to see some of the conclusions that I came to.
Ref digital processors, from a pure definition you're correct. However there are numerous "AV processors" out there that pass through analogue from either stereo or 5.1 sources and do not digitise it. IIRC the Audiolab is an example, and according to what I read, the Bryston SP1.7 is another. What I was trying to suggest is that if you're a vinyl user, IMO you'd be better off going with something that can deal with analogue pass through such as the Bryston, or for that matter, my existing Thule. The Meridian doesn't have that functionality.
Correct Mr_S, my "AV Processor" or "AV Pre Amp" or what ever it should be called. Is programable/controllable to behave as you want.
Hook it up to an analogue source, in my case LP12 vinyl, Akurate DS and SACD player, then program the inputs you have used. So it will shut down all unused circuits, so the video board is switched off when listening to a vinyl for exampe.
Switch to the DVD input, the DAC's get switched on it behaves like most other AV processors, giving up to 7.1 with various processing options.
If you choose, you can allow it to process an analogue source into a "surround option".... can't say I have ever felt the need.
One option is "Stereo + Sub".....believe this option is not digitised either, and sometimes helps out some poor mastered albums.
SACD/DVD-A is handle as an analogue passthrough, but with video output to allow track information to be displayed on a screen.
The Unidisk player is also connected via 232 lead to the amp, so they auto switch what's required depending on the type of disc you put in the draw.
Choosing either the analogue hook up or the SP/DIF, and any sound processing if required.
All this is set up by plugging a keyboard into the amp, and creating "profiles" on screen.
What has also been good, is you can create unique profiles for different locations or system set-ups. So when I went to Italy I created a new profile for that house and equipment set-up, and kept my UK set-up for my return.
Add to this the "amp" is also a multi room controller. It will share a unique source from the main room, to 4 other rooms, and the other rooms can control and select what they want to listen to. Not for everyone, but I used this for 2 extra rooms in the past.....when the main room was busy with "Eastenders" LOL.
The beauty of the amp is though is it's excellent "stereo" performance, it was developed to be as good as 2 channel stereo pre-amp, but with added features.
The point of this ramble, as Mr_S was showing, some great legacy kit about, and not all "AV processors" are made or sound the same.....
Oh the automotive industry is in a bad way, and not offering many interviews at present.....everyone needs to rushout and buy a new car...please ;)
Nice Meridian there & quite the write up Mr.Sukebe - my approach is to paraphrase with cryptic clues so no-one ends up understanding it :D
As you've pointed out w/out spending huge sums at the moment there's just no way to get decent processing with native hdmi/hd audio functionalty - but a player which encodes to 1.5mbps DTS will sound better on your setup than most native HD setups anyway plus you get the benefit for legacy formats.
I am having a blast watching movies/tv shows that i know very well and hearing new sounds and even low level soundtracks that weren't apparent before that just bubble away quietly in the background, the low noise floor of good processors is something else.
I have to say that I was intrigued by the idea of the re-encoding Samsung units (and new Oppo for that matter).
As I understand it, it wouldn't make any difference to DTS-HD, which already outputs coreDTS at 1.5Mpbs via SPDIF from any BD player. However, I understand that it will output max bitrate DTS from both BD disks with LPCM and TrueHD.
How do you feel it compares against standard DD from the same disk?
I'm conscious of the fact that I'd need to buy a new BD player. I know they're available for £130 now, but I'd then have to bugger about getting it installed into the system.
No direct experience to be honest just what i've read about here and there, i am more or less in the same position than you although i am also looking at analogue players.
Worth a punt as they say - it's likely that it will benefit setups with good resolution over standard DD.
