what I said was that Thermalright made a better passive cooler, so why not buy that one?
The LGA775 bolt down kit does come with top and base brackets and 4 nice screws. It's the same retention mechanism you're using on the TRUE, actually.
I've bought and used half a dozen Thermalright LGA775 bolt-thru kits over the past year and they don't come with a hold-down clamp of any kind, just a backplate and four screws . .
All you do is stick on the backplate, remove the intel plastic push-pins and use the four supplied screws to attach the heatsink . . .
Since there is no hold-down clamp included in the Thermalright LGA775 bolt-thru kit I don't see how it can be used with a Thermalright HR-01X which is socket 771 and as far as I know socket 771 has different heatsink mounting holes to socket 775
I wanted a Thermalright HR-01 or HR-01 Plus but they do not appear to be for sale in the United Kingdom and haven't been for several months, therefore I cannot comment on their performance since they are vapourware. The only nearest alternative is the XEON fitting Thermalright HR-01X which as already explained does appear to be compatible with a Socket 775 system.
Because of all of the above I plumped for using the Thermalright Ultra-120 Extreme as a *passive* cooler. Yes I agree it's designed to run optimally with some kind of fan attached but I am please to confirm it cools rather well when running *passive*. As far as I am aware the TRUE is designed to be paired with
High-Static-Pressure-Airflow and the HR-01 family is designed to run with
Low-Static-Pressure-Airflow, this means that out of the two the TRUE will give the best cooling out the two is using a Powerful 120mm fan and the HR-01 family will give the best cooling when running *passive* or with a quiet 120mm fan that delivers gentle airflow.
Passive cooling is not a one size fits all solution but for people with good airflow in their cases, a 45nm micron undervolted/overclocked processor it works very well and in relative silence with a tad less electric consumed.
Sorry for the long reply and it feels like I am stating the obvious but all I did in this thread is reply to
paul_31 who asked
"Does anyone run the True without a fan attached? How do you think it would cope?"
I think the problem comes from the fact my answer was aimed at Socket 775 users and some people reading my reply assumed I was reffering to an overvolted/overclocked Intel® Core™ i7
I shall be more meticulous in my future posts to avoid any further mis-understandings!
