Asus GTX285.....
You get a 300% overclock on it!!!!11!!11!!1!!!
Realistically, it's a 285 - so big chunk of change for a small boost over a 275. I'd live with the 4890 until the next gen arrive tbh.
I'm gonna put the 4890 in another build and will probably buy a dx11 card when the high end nvidia ones are released which wont be untill the new year at the earliest apparently so the 285 will be ideal.
if your looking for a card to do until DX11 comes out just get a 4890 more than ideal for a temp card until DX11 and you can always re-sell it while the 285 will see a huge drop in price when you just spend quite a bit on it.
I already have a 4890 as stated in the original post and its crap, no more ati cards for me, I want the 285 cos its resale will be greater when the dx11 card do get released and at £229 its not expensive. If i was buying to keep I would go for the 295. Just want to know whether its the one with the ml caps.
