Could someone tidy this pic up for me please?
Hi,
It's not a bad pic already, except for the totally blown highlights on the wall on the right hand side...
No amount of post processing can get back what isn't there I'm afraid. :(
Have you got an original colour version, or maybe one in RAW?
What did you want 'tidying up'?
Crop to remove the wall to the side, the R on the door frame needs removing, the water cover in the path and the secruity light remove too, and its half way there. The rest will be the wires along the centre of the picture. That could be a tad hard to remove as there is a lot of them.
On 2nd looks, leave them in and remove the white arial from the top right of the picture in the sky, after then, it will be a classic picture, good effort, just needs a few tweaks. Also the wire by the arial down to the second window, remove that, i know its natural but it doesnt half pull your eye.
8/10, good picture, I truely wish i was there and had the eye to spot that!
ColiNfr.
ColiNfr.
Thanks for that mate, appreciate the score you gave it!!
Sadly I took the photo using the black & white option on the camera. If memory serves me correctly the bike was cream/silver. Which is a shame as if it was red or something it would look great!
I quite like the blue!! :)
Although the red looks ok too...
Keep the blue, tones in with the picture much nicer than the red. Also, if you can and have the time, remove the security light and the grill? on the corner of the building.
The white line is still there too.
WOuld it be possible to see this pic with the top left pulled out a bit to make the wall of the building straight?
The more i look at this picture, the more i like it... 8.5/10 now :)
ColiNfr
The blue looks pretty amazing :)
Would it be possible for you to remove the security light (on the left hand side?).
Also could you send me the file over email? gtruman at ukfsn dot org
Really appreciate it :)
IMO the selective colour ruins that shot, the blue looks bad, the red looks worse. What is the point in highlighting the colour of the scooter? It just seems like a random thing to do and in no way does it compliment the shot. All is does is draw my eye to the scooter and away from the lovely architecture.
Keep it black and white and you have a nice photo.
^ All my opinion, so feel free to ignore :)
I've sent you an email with the photo attached with the changes you requested. :)
