Ladies and Gents,
After having owned my Mk V GTi for no more than 3 days, I've encountered a major problem with it. Starting the engine, I instantly smelt burning. Fine white smoke was coming from underneath the bonnet so I quickly turned off the ignition and opened it up. I removed the engine facade cover and it was clear that the smoke was emerging from Cylinder number 1. It was the connector that goes into the Coil Pack. It must have shorted and melted the plastic so it became so hot that it started to burn.
This smoke stoped after a minute thankfully and after a day of trying to get my vehicle recovered to a garage (luckily it was on my girlfriends drive) the garage have come back with the following. (I might add that the original purchase garage provided a 6 month AA 5 star guarentee for such problems so it has been taken to my local AA Approved garage called "Nationwide Autocentre" in Bletchley).
They've informed me that all the clip lugs that secure the connector on the wiring loom that goes to the coil packs have been snapped. After phoning the garage that I purchased the vehicle from, he said that this is common becuase they get so hot and the plastic gets brittle. Fair enough.
The third party garage (Nationwide) are now saying that they think its going to cost £1200 to fix. They say that they think the wiring loom or Coil pack wiring harness is connected to the rest of the engine loom and think that you can’t get the part on its own. I’ve only a few quick questions:
1) If they’re going to replace one coil pack under warrenty, is it worth trying to get them to replace all four?
2) What is the price i should be paying for a Coil Pack Wiring loom (I know that the 1.8T engine had a seperate wiring loom) with fitting?
Sorry for the long post but i’m sure you can understand my fustration!
Thanks
Greg
Thanks
Greg
