- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Lancool Dragon-Lord PC-K58 Mid Tower Case - Black (No PSU)
The Dragon Lord K serires builds LanCool’s high standard of Quality requirement. This SECC steel cases with completely tool-less design are the perfect complement to a PC gamer’s needs. The cutting edge tool-less design is an important key feature in the new LanCool cases. The LanCool design team considered end user requirements, especially home-builders allowing for faster component swapping. The new internal layout has the motherboard on top of the power supply unit, which allows for easier access to the motherboard as well as more room above, thus larger CPU coolers can be used. The power supply unit at the bottom of the case is cooled with fresh cool air directly from the outside of the case. The Dragon Lord K58 is equipped with large cooling fans, with low RPM, which still provide enough air flow to cool down the hardware adequately. The front 140mm intakes fan runs at 1000RPM. The top two silent 140mm ball-bearing fans exhaust the hot air out at 1000RPM. All the intake fans are aligned with inlet holes on the bezels. These are equipped with air filters to stop the dust and keep the internals dust free and clean.
- Motherboard Compatability: ATX & M-ATX
- Side Panel & Body: CECC Steel
- Front Bezel: Plastic
- 5 x 5.25" Drive Bays
- 4 x 3.5" Drive Bays
- Cooling : 1 x 140mm Front Fan (included) 1 x 120mm Rear fan (included)
- I/O Ports: 2 x USB2.0 & 1 x Audio
Only £59.98 inc VAT.
BUY NOW
BUY NOW
