Namoroka (Firefox) 3.6 Alpha 1 released
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
And is it fast? oh yes :P
I've used Nightly Tester Tools to force compat all my themes/extensions and styles and it works as flawlessly as 3.5 and co-exists with it while I continue to check out the feature set of 3.6 :D
I'm on Win7 x64 btw. Everything just works...also Acid 3 test
Download here: http://www.mozilla.org/projects/firefox/3.6a1/releasenotes/#downloadandinstall
Javascript speed test @ http://celtickane.com/labs/web-browser-javascript-benchmark/ gives me 200ms on the dot, 3.5 gives 297.
Page rendering seems swifter too especially when saving open media content page tabs when closing the browser and re-opening them.
Niceness!
Only issue I have found while testing my most browsed sites is that quicktime (QT Lite) plugin and windows mediaplayer plugin for embedded content does not support it yet - everything else works nicely :D
The Glassing is all due to the 3.7 mockup theme + Glasser extension (see mockup thread :D)`
Hmm?
You don't by default but you do if you install the extension and theme mentioned exactly as above and tweak using the mockup thread's info.
Nightly Tester Tools is better at making extensions/themes compatible. That will sort it out.
I have just installed Namoroka and I can't say I have noticed too much difference other than, scrolling down pages is a lot faster, I think I need to get use to that and also, any words that are misspelt are now underlined with a squiggly line as opposed to flat lines. :p
Yeah the squiggly lines I like, reminds me of office and is more visible than a flat line :D
