- 12 Aug 2009
Hi there! My PC died on me and I need to get a new one asap. I have a budget of around £850 but would raise that to £950 if I could get a reasonable screen as well (no bigger than 19").
The only game I really play is Football Manager although this game is increasingly demanding more of both the CPU and GPU. I do also play Civ occasionally but I believe this game is less demanding. I do not care about overclocking as I would not have a clue, someone did tell me there is a very easy way by just upping the volts slightly but I still would not have a clue how to do that. Basically I am looking at this kind of price range hoping it will last me a few years.
I had a look at the "Ultima Warlord" on here and it seemed a pretty high spec. I would, however, update the GPU on that machine but that still sits within my budget. Wondered what people thought of the machine and of the quality of Overclockers' builds. As far as I am aware this is a reasonably new service from Overclockers so just wanted some feedback.
Here is a spec I made:
* CASE: COOLERMASTER ELITE 310 Mid Tower Case
* Power Supply Upgrade: 700 Watts Power Supplies ( Performance ATX 2.0 Power - Quad SLI Ready)
* CPU: AMD Phenom™ II X4 955 Quad-Core CPU w/ HyperTransport
* Cooling Fan : AMD ATHLON64 CERTIFIED CPU FAN & HEATSINK
* MOTHERBOARD: GigaByte MA770T-UD3P AM3 DDR3 770 Chipset 1666+/1333/1066 with PCIe slot SATA RAID MB w/GbLAN, USB2.0, IEEE1394, & 7.1Audio
* MEMORY: 4GB (2x2GB) PC12800 DDR3/1600mhz Dual Channel Memory (OCZ Gold w/ HeatSpreader
* VIDEO CARD: NVIDIA GeForce GTS 250 1GB 16X PCI Express
* LCD Monitor: 19& quot; TFT Active Matrix LCD Display (VIEWSONIC VA1916W 19& quot; 5MS TFT LCD Display Wide Monitor)
* Hard Drive: Single Hard Drive (1TB SATA-II 3.0Gb/s 16M Cache Hard Drive)
* Optical Drive: LiteOn LH-20A1H 20X Double Layer DVD±RW Super Allwrite + Lightscribe Technology (Black Color)
* Optical Drive 2: (Special Price) LG 22X DVD±R/±RW + CD-R/RW DRIVE DUAL LAYER (Black Color)
* SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
* Network: ONBOARD 10/1000 NETWORK CARD
* Keyboard: Logitech PS/2 Keyboard (Black)
* Wireless 802.11B/G Network Card: PCI Wireless 802.11g 54Mbps Network Interface Card
* Cable Wiring: Professional Wiring for All WIRINGs Inside The System Chasis with High Performance Thermal Compound on CPU
* Power Surge Protection: Belkin 6-Socket Surge Protector
* USB Port: Built-in USB 2.0 Ports
* OS: Microsoft® Windows Vista™ Home Premium w/ Service Pack 1 (64-bit Edition)
* Windows 7 Upgrade Coupon: Upgrade to Microsoft® Windows® 7 Home Premium (64-bit Edition)
This all comes out at just £848.37p. I wanted some advice as I could still knock some money of this build. Do I need that high a GPU? I can knock £15 off and get the 9800gt 1gb which I've heard is a great card? Also would anyone recommend me getting a different case or do you think that would be adequate?
Thanks in advance for all your help! Sorry about the length of this essay!
