I wish this board were available sooner, J&W make great boards at an affordable price, but they always seem to show up much too late.
That's probably because of UK retailers though?
Id like to see the bios settings, + how this board would run a 45nm quad on high fsb, ive only run 450fsb on the p5q dlx, ive heard the gigabyte board is better again, wouldnt mind seeing how the j&w stacks up against the competition.
and I still miss my P5Q Deluxe. It was so easy to clock...every other board I've tried has been finicky when it comes to memory settings. Also the way the gigabyte board recovers from a failed overclock is MOST annoying and is killing my hard drives.
no idea which brand it is?
As the UK's No. 1 J&W Fanboy I'm sure many of you will know that I like J&W Motherboards, so when I discovered a new one was available in the UK I ordered one.
It arrived this morning!
As usual for J&W it came in a nice black box.
The bundle is a bit uninspiring, but then this is the budget P45 from J&W, the Extreme being the top end model (not currently sold in Europe).
The board itself is J&W's usual high standard of build quality.
The SilentCool heatsink is taller than many, but it sits well back from the socket and even bigger coolers like the TRUE and Scythe Mugen don't foul the chipset cooling.
The SilentCool is a real heatpipe cooler (not just a copper coloured tube) and it's very efficient in initial testing. Note also the DFI style PCIe slot.
The back panel has everything most folks would want, including optical and phono style digital audio, 6 USB ports and the all-important BIOS reset switch. This is an overclockers board!
