Anything I Need To Revise Before I Order??
It should be enough yes... however if you plan to overclock, and even add a second GFX card I would go for the 750W or even the 850W.
Never scrimp on a PSU it's probably one of the most important components in a system and you usually get what you pay for.
Couldnt i just use whatever is holding the cosair fan to the rad though, as thats the fan i would be removing and replacing with the apache?
Some sound advice, some shocking.
SSD is unnecessary, especially since there's a limited number of times it can be written and rewritten.
850W might be a bit much, it's just going to hurt your electricity bill :p
I don't know which comment is more shameful. The former suggests you are so far out of the hardware loop that you shouldn't even be contemplating giving advice on ssds, and the second demonstrates that you know sweet fa about electricity. Not a good post.
This man is repeatedly recommending fan clips made for a specific, nominally passive air cooler to use with a completely unrelated product which doesn't need any.
SSD isn't really 'unnecessary' as it is much faster...
850W may be a slight overkill... The Corsiars are fairly efficient. If anything it will help his electricity bills.
Xonar and X-Fi, they are just better at different things...
The fans he has chosen are superb...
This man's on the ball though, I agree with everything he's said.
Single card over dual is normally preferable, it avoids general driver problems and cuts the noise of the system considerably. The 285gtx is a beast, even faster than the monstrous 280gtx but not as inclined to burn a hole through the side of your case.
Processor and board I like so much I own them. The ram is what I would have bought if I wasn't fixated on watercooling everything. I'd want the 850W corsair personally, since it'll be cooler and stressed a lot less. I massively overspec power supplies though, a 400W would drive my system fine and it has an 860W in it.
Not the ssd I'd have chosen. Personally I'd want an ocz drive, either the 60gb vertex or the 120gb agility. Probably the latter, I'm using the amazing vertex at present but would have bought the saner agility had it existed so long ago.
One thing to consider, though it would be a complete rework of a lot of your spec. You've not mentioned a case. Or water. So I'm going to assume you're air cooling and would like a new case. I strongly recommend the exceptionally good antec mini p180. It will do an excellent job of cooling your graphics card and hold the corsair cooler with no problems at all. It requries a move to matx, which means evga/asus/msi who all make lovely matx x58 boards. Who on earth uses 7 peripheral cards these days though. Of course you could use the P193 or similar, and it'll cool a bit better, you can use the amazing gigabyte board and fit mad numbers of hard drives into it. It'll be bigger though, and small is beautiful. Computers that manage to be small, beautiful, quiet and obscenely quick are perfection in my eyes.
Cheers
Thanks for the informative post JonJ678, i shall be using my current Antec 1200 case, and will be sticking to air (apart from the H50 cpu cooler). I'll take a look at the agility.
Just how loud & hot do the 285gtx's get compared to the 275gtx's?
Are we likely to see the current i7 920 Do coming down in price when the i5's etc hit next month?
Power consumption
Geforece GTX 275
* System in IDLE = ~210 Watts
* System with GPU in FULL Stress = ~396 Watts
Geforce GTX 285
* System in IDLE = 228 Watts
* System with GPU in FULL Stress = 420 Watts
Noise
Geforce GTX 275
39-41 dBA
Geforce GTX 285
40-43 dBA
Temperatures
Geforce GTX 275
Idle: 41 C
Load: 88 C
Geforce GTX 285
Idle: 47 c
Load: 92 C
Taken from Guru3D.com
Makes me laugh when people say how the NVIDIA cards run cool, especially to the AMD cards, well I don't know about AMD, but how the hell is 92 C cool? lol My mate tries to convince me his 295 doesn't go above 60C... I'm just thinking, yeah, that's because you have no idea what 'LOAD' means :rolleyes: lol
Forgot to say, the I7's, yes it is likely they will come down in price, but only by about 10-20 quid. 1366 i7 will still be considered high end, so the price isn't going to fall very much.
Nope different socket so intel says NO!
& get a 275 the 285 arent worth the extra & avoid the corsair 620 that someone spec they are the most likly to go pop!
Cheers for the info VortX, think i might go with the OCZ Agility over the Crucial M225, as OC dont have any stock of the M225 (dont know when they will), would people say thats a good idea, as are'nt Crucial new to the market of SSD, and i dont mind paying an extra 25 quid for a SSD if it means better build quality/performance/reliability.
Now i need to make my mind up what to do on the GFX card front, do i go with the 285, or a 275, taking into acount by novemeber time Nvidia will probably have DX11 cards out?. I surposse i should explain why im deciding on Nvidia over ATI, well it down to nvidia physx, i know not all games support it but the ones that do have nicer effects (batman AA, im looking a you) and this trend will probably carry on with more and more games unless ATI come out with there own spin on it!?
Now i know ATI cards tend to be on the cheaper side, but nvidia cards at the same level have slightly better performance (in most games) and the added benefit of physx. Question is, will these DX11 cards bring me any more performace over a 285GTX if my maxium gaming res is 1920x1200?, and if not i might aswell get a 285 now instead of a cheaper 275!
OCZ customer support has been really exceptional with ssds, right from the start. I'd much rather go with one of their drives, only intel could tempt me away. Out of their current range, the agility is where it's at for larger than 30gb capacities.
285 vs 275 I can't help with, as my 8800gt is more than enough for me. Since you're gaming at 24" I suspect you want the bigger one, buying a smaller one now and upgrading later if the new generation cards are much better is a dangerous gamble
I really don't think the performance between the 275 and 285 is worth the hike in price, it's effectively a very slight overclock. It's all a bit up in the air about what the DX11 cards will bring - especially with Nvidia, and I can't really see their DX11 units being available before Q1 next year.
I also suspect Physx will become less and less relevant, but it is here now and does have it's uses.
OCZ do have good customer service from what I hear and are fast with firmware updates - but the crucial is basically the same thing for a lot less money.
In the same sort of way that crucial ram is the same thing as ocz reaper...
Theres a reason it costs a lot less. I think ocz is entirely worth the premium
