Nvidia tripple sli and dedecated phyx card watercooling?
13 Aug 2009
HI, this is my first post ever on overclockers.co.uk - so if i do anything wrong please don't bite my head off and ban me :) but i have a question, I am preping a case for the Gt300 series gpus and have never had 4 cards - what i want to know is normally with Nvidia GPUs in tripple sli is there enough room inbetween the 2nd and 3rd card to put a new loop into the third card? I would really like it if someone had anypics of their rig, i just don't want to install 3 loops and then find i can't optimise it like this
thanks
The most important thing to do to avoid being shouted at is to look carefully at the forum you're in before you post. This forum is for distributed computing which doesn't really seem appropriate for your question. If you look in the hardware section you'll find a forum for overclocking & cooling and I suggest you ask there instead.
As above, this question would be best received in the GPU or Cooling sub forums in hardware.
However it'll all depend on what motherboard you have or what board you're planning on buying? :)
Agree with the above, but I suppose once GJS1 receives advice, the effectiveness of those watercooled GPUs could be tested by running a DC project... ;)
Anyway, welcome to the forum GJS1, glad you found us. If ever you DO want to run any DC project, don't be afraid to pop your head in here again. We don't bite much :)
thanks
Does this help at all,
They are not technically triple SLi (being GTX295'S) but the spacing should be the same.
Cheers, Simon.
ahh thanks guys, i didn't even realise there were sub sections - sorry i'v just posted inn here again :S i will avoid it agai. Thanks for the welcome to, and it doesn't look like it's going ot fit :(
