Chuffed
Got a Gigabyte MA770T-UD3P and a Phenom II X3. Read about unlocking the 4th core and gave it a go in the BIOS under ACC (Set it to Auto).
No luck, so had another read, and updated the BIOS to f2c and also set the EC firmware flashing or something to Hybrid, and success!!
CPUZ shows me at 4 cores, all running swish...
I've never done any OC'ing before so where do I go now? As I say those two options are all I've changed, not fiddled any voltages or anything, also I point out I'm running the stock cooler.
Do I run Prime95 now and check stability?
Thanks for the advice everyone!
