- 4 May 2006
- Manchester
Im used to this type of start menu though. My laptop used it as it was XP. My main PC running Vista uses it. I just like that sort of simplistic menu, using a sort of tree of layout (executables inside its folder, that folder along with others in a 'programs' folder etc...)
With this stupid new start menu i have to either open folders to get to the programs instead of using a menu, have limited ammount of programs shown on the small white area in the menu, or have tons of desktop icons.
Tough, you can't have it
I find pressing the Windows key on my keyboard, then typing 'notepad' and hitting enter a billion times faster than finding it amongst the menus anyway. Once you get used to the new menu you'll find it a lot better.
