Was it you I sent an email to about Parkside Autos?can't be arsed
local place only quoted £49.50+vat for labour
If the Tyre is newish I'd be going back where I bought it if you know you've not damaged it in any way and a bump has developed.
Sell it and buy a car you can afford to run?
Can you not do the disc's and pads yourself? Not usually a hard job.
lol, at what point did he say hhe couldn't afford it?
I believe he is just pointing out the expense for 2 things that on other cars are not £1k to replace![]()
the labour is only £50+vat, not worth it
Failure's always an opportunity to upgrade, well not that you can upgrade one tyre.
Guess you can't just pop down GSF and grab some cheaper discs, not that you'd really want too!
Rotty said:local place quoted £508 for disks and pads using OEM
mmm, that does sound bad
the cost not the Rover that is
then again ..................![]()
