Cooler that faces down.
Permabanned
14 Jun 2009
Is anyone using a cooler that faces down as opposed to the type that is classed as a tower one?
If so, which one are you using and what do you think of it. I was looking at the:
Asus Triton 75 CPU Cooler
I'm not sure about the asus but before the tower coolers came out I've been using zalmans for ages and they're very good so if your case can't fit high cooler, pick any of the zalmans that aint tower type and you'll be happy.
The best horizontal cooler out there is the Thermalright AXP140 - it's almost a TRUE bent over 90 degrees. If that's too big then the SI-128SE fits most cases.
Arctic Cooling Freezer 7 Low Profile is a bit like it, but fewer heatpipes and cheaper. Smaller fan too.
The Silverstone Nitrogon NT-06 Lite is also extremely good. Not cheap though.
Horizontal coolers are very good for chipset cooling, as well as being space efficient.
