Fresh Plates - Fixing
13 Jan 2004
Screwed (Holes/bolts/coloured caps exist)
Screwed + Double Sided Stickied
Double Sided Stickied only
Is the double sided stuff strong enough to hold them on ?
Considering Screwing only however to make removal easy, 2 little sticky backed rubber feet on the lower edge should be enough to screw down and not have them flap around :D
Screws totally suck.
I used 3M Duallock I think it was called. It's industrial Velcro - they DONT come off unless you really pull, then they click off. Perfect for cleaning. Found it lying around the house.
Went to order some more... £60 a roll :eek:
You take off the number plate when you wash your car?
For a general wash? Nah.
But when the machine polisher comes out and theres accumulated crap/polish/wax/whatever around and just behind the edges of the plate I would want to make my life easier, yeah :p
[TW]Fox;14725958 said:
Sellotape double sided pads. £2.39 from Homebase. Go now.
Indeed. I used "Sellotape Outdoor Sticky Fixers". Absolutely rock solid after 18 months now and all weather. Its going to be a job getting them off when i eventually sell the car tbh :eek:
Mine has holes in the bumper so I just used the bolts - PITA to measure. Remember, measure twice, drill once :D
I found on the front the curve of the bumper made the plates stick out at the edges, so I used the pads to hold the edges in, so the plate is secure as its screwed on and follows the curve of the bumper :)
Bog standard double-sided foam tape on mine. It's super strong provided both surfaces are totally clean and degreased. Surprisingly easy to get off though, screwdriver under it and a bit of leverage and it's coming off easily.
