USB Safely Remove free licence....
But what's the point of formatting a large (over 40GB) USB drive in FAT32 when the largest filesize supported by FAT32 is 4GB anyway?
Plus data integrity is much better in NTFS volumes.
with usb keys, as long as it's not windows 2000 and the lights aren't flashing, just rip it out
you're absolutely right, but 32 and 64GB usb keys are still quite uncommon.
i'm sure that when they're more affordable, and thus more common, many people will format them as NTFS (or exFAT :p)
also, window's built-in safely remove works really well. the mistake most people make is double-clicking on it, which brings up an annoying menu.
single clicking brings up a temporary box, and then clicking once on the drive you want to eject stop it so it's safe.
Don't know ANYONE who EVER safely removes them. I know I never have, or my USB hard drive come to think of it, just rip it out. No one I know has ever had any problems.
I had a 32MB drive in 2001 and if you whipped it out without safely removing it formatted the partition, found that out the hard way :(
New ones seem fine so long as the lights have stopped flashing for a few seconds before taking them out of the system though.
I knew someone who did, he swore it would leave loads of drives that weren't actually used any more... He taught IT for a few years as well...
I just wait til it stops flashing and pull it out. Never had any problems...
Whip it out here (oo-err!). But I've found that people who aren't computer savvy think that if they don't remove it safely, it'll cause their computer to explode. My mother once literally screamed when I pulled out a USB stick about a year ago; she still didn't believe me when I explained it's fine and I've never had an issue :-/
great :tup:
its useful for me on win7, esata hotplug doesn't work properly but if i install the jmicron drivers it kills the built-in safely remove traytool.
Useful information this. I used the built in safely remove on a dodgy drive I used to have, but mainly just pull it out.
I'm sure there's a Windows option for fast removal or something which is on by default, in XP at least.
Yeah in device properties you can set for quick removal or performance. Think default is normally quick removal.
