Guys,
Fresh install of XP Pro, running IE8. Have turned off the always use clear type option, but still some sites don't look great.
Now I don't know if it's something I haven't done, or are some sites crap, or maybe it's just the way IE8 shows them?
Example... http://windows7forums.com/windows-7-support/5249-ie8-crashes-exit.html
The text on this just is not crisp at all. It looks almost as if it has a very slight drop shadow.
Any ideas or is it just the way that site is coded?
